Meraki Client VPN Connection
mahi
I have followed the steps to connect Meraki L2TP VPN in windows, but still facing an error. I am not getting the login window.
What error code does the Windows Event Viewer show you?
https://documentation.meraki.com/SASE_and_SD-WAN/MX/Troubleshooting_and_Support/Troubleshooting/Trou...
mahi
Hi, I have got the following error. based on the documentation the adapter is already allowed PAP.
Do you have a dedicated IP or is it behind a NAT.
If it's behind a NAT you can try this.
Registry Adjustment (for NAT network)
If your client or server is behind a router with NAT:
Open the Registry Editor (regedit).
Go to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\PolicyAgent.
Create a DWORD AssumeUDPEncapsulationContextOnSendRule and set the value to 2.
Restart the machine.
