Meraki Client L2TP/IPsec vpn and IPsec tunnel with non-meraki device simutaneously
JJM
Hello all,
I have a questions, that i would like to know "can i use Meraki Client L2TP/IPsec vpn and IPsec tunnel with non-meraki device simultaneously" because i cannot connect Meraki client vpn while having ipsec tunnel with non-meraki vpn.
Appreciate anyone reply.
Yes, you definitely can.
almightythor
are you using windows built in vpn client or anyconnect or some other software client? If you use windows VPN and you choose the documented settings from the Meraki website it can change. If you manually configure the adapter with PAP it will change the authentication in windows settings. You have to go back in and change that to "username and password". Many times this will toggle the MSCHAP back on the VPN adapter so you have to go back there and select PAP again. It's been a bug for a while with windows but not in software vpn clients like anyconnect. Sometimes you have to toggle the settings twice before windows will stop mangling your connection then it should connect fine. Just make sure you have CHAP off.
JJM
thanks for it. Let me try with it.
