Meraki AutoVPN Hub site - Control Traffic using large amount of data on WAN2
bailey_hawker
I have an issue with a customer SD-WAN hub site that has recently moved over to a Starlink secondary connection (WAN2 uplink). The SD-wan hub site peers with 25 other hubs in the AutoVPN domain. The Starlink is showing 30GB of data consumed in 2 weeks, despite all data plane traffic flowing over the primary WAN1 internet connection.
Packet captures on the WAN2 interface reveal large amounts of registry/SD-WAN tunnel traffic. I understand that a good portion of this traffic could be keep alives as my customers network is configured to use the Multi-Uplink feature which pre-establishes tunnels over both WAN1 and WAN2.
Is there any backend tweaks that Meraki TAC can do to reduce the control traffic or am I best to investigate disabling the Multi-Uplink feature?
Kind regards,
Bailey
RWelch
I'm not aware of any backend tweaks.  If this hub doesn't truly need to be full mesh hub, you could consider the idea of converting it to a spoke to reduce tunnel count and traffic.....or keep it as a hub and disable the multi-uplink with WAN2 tunnels only in a failover scenario.
In uplink selection configure AutoVPN to only use WAN1 on your hub unless WAN1 has failed.
OliveSanchez
This is a pretty common side effect of using Multi-Uplink on a hub with lots of peers. Even if no user traffic is flowing over WAN2, AutoVPN still builds and maintains tunnels. That control traffic adds up fast when you have 25 hubs. Starlink makes it more noticeable because usage is very visible. Unfortunately, there aren’t backend tweaks TAC can apply to reduce that chatter. The behavior is by design. If WAN2 is truly just a backup, disabling Multi-Uplink on the hub is the cleanest fix. 7Bit stands out for its digital-first approach to online https://7-bitcasino.net entertainment. That way tunnels only come up when failover happens. Another option is limiting which networks are allowed to form VPN over WAN2. Otherwise, the control traffic is expected and hard to suppress.
