New to Meraki and wish to identify upload utilisation on WAN1.
Can find lots of graphs and download utilisation but struggling to find upload.
Trying to see if my 1 mbps upload is being saturated.
thanks
Solved! Go to Solution.
You get total utilisation and download utilisation. Upload use is the difference between the two.
I hope you can find the configuration under “SD-WAN & traffic shaping” and additionally, please check whether the bandwidth limitation is being done in any downstream network as well.
Hi.
Go to Sercurity & SD-WAN > Appliance Status, there you can verify the traffic as you prefer.
Let me know if this help.
Regards,
If you have two WANs then it is a little more tricky as the main graph only shows overall for both...
