We're migrating to the Cisco Community on March 31. The Meraki Community will enter read-only mode starting on March 26 through March 31.
New to Meraki and wish to identify upload utilisation on WAN1.
Can find lots of graphs and download utilisation but struggling to find upload.
Trying to see if my 1 mbps upload is being saturated.
thanks
Solved! Go to solution.
You get total utilisation and download utilisation. Upload use is the difference between the two.
I hope you can find the configuration under “SD-WAN & traffic shaping” and additionally, please check whether the bandwidth limitation is being done in any downstream network as well.
Hi.
Go to Sercurity & SD-WAN > Appliance Status, there you can verify the traffic as you prefer.
Let me know if this help.
Regards,
If you have two WANs then it is a little more tricky as the main graph only shows overall for both...
