Mapped Drives do not connect after VPN
TooTallJack
After a user logs in with VPN it takes upwards some days 20+ minutes to connect to our mapped drives.
Any suggestions ?
We have tried enable slow links in windows, connect to VPN first - then log into the domain.
We are using Cisco Any connect - Tried a few different versions still same issue
Any suggestions this is very frustrating to our users and to the IT Staff.
A common issue with Windows.
Best fix - get rid of mapped drives and change to UNC paths.
Another common method I have seen is having the VPN or user run a script to reconnect the drives.
TooTallJack
We have tried and the unc path does not open either it takes 15+ minutes then it will with UNC \ IP\ FQDN anything.
TooTallJack
On a wire shark capture packet capture the Windows File Server closing the connection by sending a RST to the host.
We never had this issue with out old CISCO FireWall not sure how to resolve this
