Mac Binding In MX-Firewall
Somnath_C1304
Hi Comm,
Is Mac binding or Mac Filtering supported by Meraki firewall??
CptnCrnch
No, MX will filter anything on and above Layer 3.
KarstenI
As @CptnCrnch mentioned, this is not natively supported. But this feature would not be really needed in the HQ, but in the Home-office and/or Small-Office. And for tis scenario you can configure 802.1X/MAB on the LAN-ports of the MX. Will take some planning and you need a central RADIUS-server, but it will likely fit your needs.
Well, I was about to pass over this thread as answered, but on reflection, you actually can do MAC binding/filtering.
It's called group policy.  In a group policy you can put in any firewall settings you want, and then you bind it to the client (which is usually done based on MAC address).
https://documentation.meraki.com/General_Administration/Cross-Platform_Content/Creating_and_Applying...
