MX84 with advanced licensing
ptsakalos
Hello guys,
A partner of ours wants 2 x MX84-HW.
Does 1 x LIC-MX 84-SEC-5YR covers both devices or does he need 2 licenses?
Thanks a lot!
MarcP
For using them in HA mode, active-passive?
We always had 1 Lic per device. Think this is necessary.
Edit: corrected myself below... 1 lic enough in HA
https://documentation.meraki.com/MX/Deployment_Guides/MX_Warm_Spare_-_High_Availability_Pair
ptsakalos
Hello Marc and thanks for the prompt answer.
So with 2 Advanced License he will be covered right? Not with 1.
Thanks a lot,
MarcP
KRobert
If you are using them together as an HA pair, then you only need 1 license. If you are using them separately, then you will need a license per appliance. If you are using them in an HA pair, then like @MarcP said, they have to be the same model. 2xMX84, 2xMX100, 2xMX67W, etc.. In your case, since you are purchasing two MX84s, you'll be okay.
Hope this helps
CMNO, CCNA R+S
