MX84 and SFP
Riser
MX84 and SFP
Hello All,
AT&T is installing a backup internet for us. It is a 50Mbps BU / Fiber S14. This requires an SFP port on the Meraki to connect it to. We are using an MX84 which I don't think allows SFP for WAN interfaces. What should we do?
Any advice?
2 REPLIES 2
You can use a media converter.
As @alemabrahao says, a media converter is the hands down cheapest option.
If your current Meraki licence is getting close to expiring, you could consider upgrading to the newer MX85.  This includes a pair of SFP+ WAN ports, which you can plug an SFP into.
