Solved! Go to solution.
@Anukul_Tiwari we had all of our MX84s rebooting every 20 days or so, with 17.10.2. Upgrading to 17.10.4 appeared to fix it.
Hi ,
Haven't seen that issue in the wild yet but MX 17.10.4 has a fix for :
And MX 17.10.5 :
So MX17.10.5 might help , but I would involve Support to look at the reboot reason ( crash ? reboot ? )
Thanks for the response
I guess that :
Wasn't that rare haha !
You can also get this when the MX is overloaded. You can check the usage on the Organization Summary page for the specific network it is in. You want this to be kept under 80%.
Did the issue get resolved with the 17.10.5 version upgrade? We had Cisco Meraki support recommend upgrading to the 18.106 stable release candidate.
Thanks for any feedback.
