MX80 not shown on the equipment column
PPERERA
Have a MX80 shown under License Information but cannot see it listed on the equipment column.
How can I please find out the configuration details on MX80?
PPERERA
Thanks for your directions. I have managed to get ahead with your instructions.
thanks again.
2 Replies 2
GreenMan
Meraki Alumni (Retired)
It sounds like you may have a valid license for an MX80, within your Dashboard, but that you don't have a hardware device to match.   Search for MX80 under Organization > Configure > Inventory.    If it's not there, then it's not actively deployed (remember not to include in your Dashboard renewal, when that comes around).   If it is there, take a look at the Network in which it is placed (you'll probably need to add the extra Network column to the Inventory table to see this).  If it's not in a Network, then it's not in use.  If it is, click the Network name and look at the various config options under Configure in the Security & SD-WAN menu.
PPERERA
thanks again.
