MX68W Dashbord doesn't have an icon to view application details
aren1
Hi Everyone,
I want to analyze about the client/IP application details in MX68W.
But Dashbord doesn't have an icon to view details. Is there a solution?
Picture in below
Aren
Brash
Likely because you've only just enabled it. It will need time to build up.
6 Replies 6
Brash
Do you have detailed analytics turned on for that network?
Check under -> Newtwork wide -> settings
aren1
My dashboard doesn't have a settings icon.
Brash
Sorry, it should be under Network Wide -> General
aren1
OK, I've seen the icon details. But it shows that the data is insufficient 😢.
Brash
aren1
Thank you very much, I have another question, can Meraki mx68w view traffic flow like a firewall, e.g. when did you access this site or what sites are you blocked?
