Solved! Go to solution.
Likely because you've only just enabled it. It will need time to build up.
Do you have detailed analytics turned on for that network?
Check under -> Newtwork wide -> settings
My dashboard doesn't have a settings icon.
Sorry, it should be under Network Wide -> General
OK, I've seen the icon details. But it shows that the data is insufficient 😢.
Thank you very much, I have another question, can Meraki mx68w view traffic flow like a firewall, e.g. when did you access this site or what sites are you blocked?
