Looking at Boosting the signal on an MX68CW but the Antenna aren't removable, unlike the MX67C that is also used in the network.
Is there any way to remove the Antenna so an external Antenna can be used?
Solved! Go to solution.
No, there's no way to remove the antenna without breaking warranty and potentially damaging the device.
That's what I feared.
