We're migrating to the Cisco Community on March 29. The Meraki Community will enter read-only mode starting on March 26.
As we know, MX68CW has 2 antennas.
I'd like to activate or deactivate the antennas in the dashboard or by other way.
This is for OTA(Over The Air) test.
BR,
CK
Solved! Go to solution.
I think you can only enable or disable the cellular modem as a whole.
Thank you.
I would like to check if the antenna is correctly functioning.
So,
I'm wondering whether we enable or disable the antenna each other.
