MX68CW Cellular doesn't work if Internet port is active.
We had a failure yesterday where our internal internet connection went down. The Meraki's lost connection to the Meraki cloud. But as the Internet port was still up, the Meraki did not failover to the cellular.
How can I make it fail over to cellular if the Internet port can't reach the Meraki cloud?
I bench tested it and found that if I unplug the Internet cable, cellular does kick in. But it doesn't kick in if Internet cable is plugged in, even though it can't reach the Meraki cloud via this cable.
5 REPLIES 5
Re: MX68CW Cellular doesn't work if Internet port is active.
It will failover in about 5 minutes in this case.  You have to wait for the uplink tests to failover.  The failover time is not configurabale.
https://documentation.meraki.com/MX/Firewall_and_Traffic_Shaping/Connection_Monitoring_for_WAN_Failo...
That's incorrect. We had no external internet for over an hour and during this time the Meraki's were offline to the cloud.
You mentioned you have a bench test.  Have you tested to see if the cellular is set up correctly?  The cellular only kick on if the hard line goes down.
In that case, at least one of the uplink monitoring tests must have still been working.  You must have had a partial outage - which is a real horrible case to deal with.  Hopefully that wont happen with your ISP very often.
You can do a further test if you like via the local status page.  Configure the WAN circuit to have an invalid configuration (such as changing the VLAN, changing from DHCP to PPPoE, etc).  This will cause the link to remain up, but the uplink monitoring tests will start to fail.
That's my whole point. With the Internet 1 link plugged in and 'active' i.e. has a green light, the cellular will not kick in. Problem is that the Internet 1 was unable to get to the internet, so the Meraki went offline rather than trying the cellular.
Was hoping there was something build in that could see that Internet 1 could not get to the Meraki cloud, so it would use the cellular instead.
