I'm trying to configure an MX68CW as a backup cellular gateway in case the primary and backup internet connections fail on a HA MX105 pair. I plan on using the USB connection on one of the MX-105's to connect to the MX68CW (functioning as a cellular gateway) as internet failover. Therefore, the MX68CW is configured in Passthrough mode.
I've factory reset the MX68CW prior to configuration and followed the steps outlined in this document under the "Setting up Cellular Failover" section.
The status light on the MX68CW is solid purple, which means it should be working fine on cellular. The attached screenshots confirm that as well.
However, the device is not able to connect to the Meraki cloud over cellular, but only works when it's connected to the wired connection. Does anyone have any idea why that's the case here?
