Hello!
I'm wondering what would be the best way to configure and connect 2X MX68 and 2X C3850 together.
In this topology, SW1 and SW2 are Layer 3 switches doing the routing between VLANs. They also have a Layer 3 link between them to avoid loops in the layer 2 domain.
With only 1 switch, I would do no switchport and assign let's say 192.168.1.2 on the routed port of the C3850 switch. On the MX, I would put Port3 as an access port in VLAN50 and configure the subnet as 192.168.1.1. SW1 would have a default route pointing to the MX (192.168.1.1) and the MX would have static routes for VLANs 150,160,170 pointing to SW1 (192.168.1.2). Clients below would have SW1/SW2 (HSRP) as their gateways. Now how would you configure the same setup in redundancy ?
Thank you
Carl
![Capture.PNG Capture.PNG](https://community.meraki.com/t5/image/serverpage/image-id/14109iBC0AEA45B60C1AE6/image-size/medium?v=v2&px=400)
