MX68 Unable to Save Setting after configure
Rae
Hi guys,
I am having an issue where I try to configure my MX.
Issue is that after I entered all the configuration and when I tried to save the setting, errors pop up mentioning that there is one or more errors found. Please fix them and try again,
Reset the appliance and the same error still occurs.
I wonder if this happens before to you?
Brash
What version is the MX running, and what is the configuration you're applying?
Also take a look at this issue on 18.207 and see if it matches.
https://community.meraki.com/t5/Security-SD-WAN/MX-18-207-on-MX67-local-status-page-bug-with-workaro...
1 Reply 1
Brash
