Today that is not an option. Hopefully one day it will be. What I always do with MX’s is use the notes field to list out the port mappings for both the WAN and LAN ports. I know it’s not exactly what you’re seeking, but it at least gets some information in there which can hopefully be helpful to admins.
Ryan / Meraki Solutions Engineer If you found this post helpful, please give it
Kudos. If my answer solves your problem please click
Accept as Solution so others can benefit from it.
