MX67C Nano SIM Bandwidth Capability
johnnyngena
On the MX67C, are the bandwidth limits or capacity for the Nano LTE SIM the same as those for the other WAN interfaces as described in the datasheet?
Thanks.
2 REPLIES 2
Ryan_Miles
The MX67C has a cat 6 LTE radio which is rated at 300 Mbps down/50 Mbps up. So, I would expect to see those numbers as a maximum value.
The wired WAN interfaces should support up to 600 Mbps up/down.
Thank you Ryan.  Would this be the same for the MG21?
