MX67 with a domain controller/dns managed server 2016
LSgroundcontrol
Just browsing
I am stuck with IP conflict and need a video on how to setup mx67 with a DC.  Thank you for any help.
7 Replies 7
Configuration Overview
The following steps outline the required configuration (both in Dashboard and Active Directory) to allow for AD-based group policy application. Please be sure to follow each step as accurately as possible, errors can be difficult to diagnose and resolve.
  1. Create an Active Directory site for the MX so users authenticate against the correct Domain Controll...
  2. Enable security auditing on Active Directory Domain Controllers so the MX can obtain all relevant lo...
  3. Enable the Global Catalog role on each Domain Controller because the MX uses LDAP/TLS over TCP port ...
  4. Install a digital certificate on each Domain Controller for LDAP/TLS.
  5. Certificate Requirements for TLS
  6. Create groups in Active Directory which will be mapped to Group Policies in Dashboard.
  7. Add users to groups in Active Directory.
  8. Configure Group Policies in Dashboard.
  9. Configure Active Directory Authentication in Dashboard.
  10. Create LDAP group to Group Policy mappings in Dashboard.
Multiple Language Server Support
The support to query Microsoft Active Directory servers configured for non-English languages is presently not supported. This functionality is currently under consideration by the Product and Engineering teams. We do not have an ETA on implementation.
https://documentation.meraki.com/MX/Content_Filtering_and_Threat_Protection/Configuring_Active_Direc...
LSgroundcontrol
Just browsing
I just need my mx67 appliance to pass through its static IP to my network, server 2016 ( DC is my dhcp/dns).  Not sure what to or how to set the WAN IPv4 confi manual?
LSgroundcontrol
Just browsing
confused to what should the MX IP, subnet, gateway and primary dns as I am a partially dumb and CEO with no network admin at moment.
In that case I suggest you hire a Meraki partner company to help you.
What do you want the MX67 to use the DC for?
How does the IP conflict fit into this picture?  What is broken, and how do you see the issue?  What do you see not working?
LSgroundcontrol
Just browsing
I have a windows server as dhcp/dns 2016, i am not sure what IPs i use for the static lan/wan.  I am bringing in a verizon mobile home cellular modem and connecting to my mx67.
that said, stuck on what i use for the IPs to tell meraki to directly go to my dns server 10.0.1.100 ?
I think it might be easier to use the Cisco Partner Locator:
https://locatr.cloudapps.cisco.com/WWChannels/LOCATR/openBasicSearch.do
And find someone near your location to come in to help.  I'm sure the investment in their time will be well worth it, and will also help get you up to speed.
