MX67 wireless performance question - expectations / tuning
ralbach
Sitting 3 feet from my MX67 and connecting to its base wireless I get 17Mbps.
Accessing the AP 40 feet away I get 38Mbps.
Wired connection gives me 100Mbps.
Would you expect this range of performance?
If not, what tuning suggestions would you suggest to improve the former (direct access to the base unit's wireless).
Thanks!
2 Replies 2
Disable 2.4Ghz.
That helps. Thanks
