MX67 Netflow and NBAR... where did it go???
robcowart
The Meraki MX67 used to send application IDs in the Netflow records when both Traffic Analysis and Netflow are enabled. This seems to have been broken or removed in some firmware update. I see applications in the Meraki UI, but not in the Netflow records (confirmed using a PCAP of the Netflow records). Is there anyway to get this back? Perhaps some other obscure config option that I am missing?
5 Replies 5
In this case, if NetFlow traffic reporting is already enabled, the best option is to open a support case.}
https://documentation.meraki.com/MX/Monitoring_and_Reporting/NetFlow_Overview
robcowart
Can anyone confirm when this functionality was removed?
Hi, how are you? Did you have a chance to check out what I suggested? 😊
robcowart
Not only did I say in my original message that "Traffic Analysis and Netflow are enabled", but also "confirmed using a PCAP of the Netflow records", which I could not do unless there were Netflow records being received from the device. So basically your message sounded like you didn't read mine.
I'm sorry, maybe I missed it, but I also suggested contacting support. 😉
