MX67 Hard Code WAN Speed
eroche
Hi All
Looking to configure our MX67 with a Hardcoded 100MB. Is it possible, can't seem to find it. If so, where is it located?
You can set the WAN port to 100Mb/s speed from the local admin page:
eroche
Thanks @cmr
I don't have the device in front of me, its at a remote location. I should be able to browse to one of the LAN IPs as long as the status page is enabled, correct?
Yes, you should be able to access from the local LAN by browsing to the MX's IP.  You might need to remote onto something local to do that.  You can WAN enable the page, but that is risky!
