MX64W - latest firmware - Client VPN weirdness
alceryes1
I set up a new client VPN user with Meraki cloud auth. (then wait an hour plus), but I cannot connect to VPN with that user account. Authorized for client VPN is 'Yes' and no expiry is set for that user. I know all the Windows 10 VPN-specific settings are correct since I can connect if I use the primary Meraki administrator account info at login instead of that user's.
Any ideas?
1 Reply 1
Sounds like you'll need to open a support case for that one.
