MX64 maximum internet speed
JasonWynn
I’m using a MX64 with an internet connection speed of 200 mbps. I am thinking of upgrading to a 350 mbps internet connection.  Will the MX64 be able to handle the additional speed increase or will it trottle the internet speed?
3 REPLIES 3
It will software limit its performance to 250Mb/s.
An MX84 can do up to 500Mb/s.
So if the broadband is 350 Mbps it will be around 43 MB/s so it’s still easily within the range... sound right?
No.
Your are proposing using a circuit which is 350Mb/s, which is about 35MB/s.
The MX64 is software limited to 250Mb/s, which is about 25MB/s.
It will work, but you will not be able to achieve the maximum performance of your circuit.
