MX64 light white flashing constantly
pbrand
Hi, the dashboard shows firmware up to date but UI shows upgrade at 0%. Is there another way to upgrade the device? I have tested to upgrade to beta version which shows success at the end but no change in UI.
GreenMan
I think you need to raise a case with the Meraki Support team - they'll be able to see precisely what the MX is doing and help from there.   Different choices for accessing Support are available under Help > Get help in the Dashboard.   Be aware that telephone receives priority, for rapidity of response.
pbrand
Many thanks for the quick answer. I have opened a ticket.
Inderdeep
@pbrand : Meraki support, most probably you will get RMA
https://community.meraki.com/t5/Security-SD-WAN/MX65W-LED-is-constantly-flahing-white/m-p/4114#M1084
www.thenetworkdna.com
