Hello, I have the following question and scenario:
MX64
- Active-Active Auto-VPN Disabled
- Load-Balancing Disabled
- Flow Preference uplink Off
- Hub & Spoke Topology
MG21
- Up Registered and Connected to Meraki Dashboard
When we shutdown the WAN1 interface and force failover, VPN tunnels still down but link is connected to WAN2 on VPN Status.
This scenario is with some sites, there are sites where the tunnels works well with LTE and another sites where doesn't work with LTE failover with MG21. (Signal poor, good, high and so on in both scenarios).
Do you need some signals specification to up tunnels? I Understand that Meraki LTE best practices is with high signal.
Do you need some fix rules in Firewall to NAT?
Anything?
