MX64 MPLS/Internet
3ffdot
MX64 MPLS/Internet
I currently have a Cisco 2811 setup at one of our branches.  It has an MPLS and internet connection on the fastethernet interface using subinterfaces (one physical connection).  I want to know if the MX can be setup in the same manner.  It doesn't seem to have this feature on it for subinterfaces but I might be missing it.  I have the router interface config and the static routes below, any advice would be helpful.  IP's are just for example purposes.
interface FastEthernet0/0.300
description **INTERNET**
encapsulation dot1Q 300
ip address 21.21.21.106 255.255.255.252
ip access-group INTERNET in
ip nat outside
ip virtual-reassembly
end
interface FastEthernet0/0.200
description **MPLS**
encapsulation dot1Q 200
ip address 11.11.11.10 255.255.255.248
end
ip route 0.0.0.0 0.0.0.0 216.81.55.105<---Internet
ip route 10.0.0.0 255.0.0.0 100.64.1.9<---MPLS
ip route 172.16.0.0 255.240.0.0 100.64.1.9<---MPLS
ip route 192.168.0.0 255.255.0.0 100.64.1.9<---MPLS
5 Replies 5
Adam
Security Appliance>Addressing and VLANs.  I think you can make multiple VLANs then just assign those VLANs to the physical interface?
@Adam I thought about going that route and putting layer 3 IP's on the MX but I'm not sure it works as an actual router.  I don't think you can assign more that one WAN IP to the MX.
It is not easy to make this config work.
Configure a LAN port as a trunk port, and plug your circuit in there.  Configure another port as an access port in VLAN 300.  Then run a patch cable from this LAN port to a WAN port on the MX.  Your MX now has its Internet port connected to the correct VLAN.
Create a layer 3 VLAN on the MX for VLAN 200, and then add the three RFC1918 address routes.
@PhilipDAth
Very interesting setup. Do I create a layer 3 VLAN in VLAN 300 as well?  It also has a static IP currently.
No, VLAN300 should be layer 2 only.
