MX64 Anyconnect VPN Clients cant print
Mrsotek
HI There,
MX64 setup using AnyConnect & Meraki Cloud Authentication.
Clients can connect and get to RDP, Files, Folders etc on Server etc, however they cannot print (i can see the printer but cannot ping said printer)
I can ping the router, server, external sites etc - but not the printer and the printer simply fails to print?
Allow Local (Lan) access is ticked on the Secure client - but obviously i am missing something basic?
Router IP 192.168.100.254
Anyconnect VPN Subnet is 192.168.102.0/24
My Internal IP used for testing is 10.10.100.17 & my router is 10.10.100.254 (again like the client i can connect but cannot print or ping myself
Mrsotek
It would appear that when configuring the router this setting didn't save to enable the Local Lan side to work
"Send all traffic except traffic going to these destinations" & configure a 0.0.0.0/32 route
Mrsotek
Malwina
Hi!
Upon saving this setting again, were you able to proceed with printing?
#1 most likely cause - incorrect P configuration on the printer.  Check the subnet mask and default gateway on the printer.
