MX450 - 1:1 NAT; outbound IP?
Drache13
I'm Migrating from some ISRs to a MX450.
2 WAN Links
an ISP provided /30 is on a Switch - and I have my first IP from my /27 on the MX. (both WAN)
I have configured a few (12?) 1:1NAT - but all but one of them do not route back to it's 1:1 IP address.
they don't even route back to the same interface (WAN1) but outbound on WAN2.
due to proper security SSL settings - this obviously breaks web apps and sites.
I was wondering if anyone experienced this - and what a possible solution is? (I'd prefer to keep the MX as an edge device)
4 REPLIES 4
LV_MW_MSP
If I remember correctly, there is no way to NAT outbound traffic to a specific IP address. You can NAT it out to WAN1 or WAN2, but to NAT out to ip #2 on WAN 1 I don't believe is possible. Maybe there has been a feature released allowing this since the last time I had this problem (about 6 months ago) but not sure.
I would try calling Meraki support and see what they say.
BA
I really don't understand -
this was a touted feature during demonstrations. (bi-directional NAT)
does this technically break web servers that require the return path to match the incoming path? (reverse route)
That is 100% dependent on your setup. I will say though even though Meraki lacks this feature, and some other ones you would think are common, I have never hit a "there is no other way" to obtain the end result.
Contact Meraki support and see if they have a beta firmware or something you can try, otherwise you will have to figure out how to make it work within the limitations of Meraki.
This wont break SSL or web apps.  If a request is NAT'ed through from the outside world the reply traffic from the web server will return via the same path (using the same 1:1 IP address).
