MX250 sometimes rebooted
AlexanderDrago
Hello!
I have some problem with Meraki MX250. Sometimes Master MX is rebooting. What problem it's can be ?
On all devices we have latest firmware.
Adam
Seems you are not alone.  @hilehoffer posted about the same thing here
https://community.meraki.com/t5/Security-SD-WAN/MX250-Stability-Issues/m-p/26639
hilehoffer
In my case we did not actually do a warm spare just Data Center redundancy.  I think our issue may finally have been resolved, we had a firmware upgrade that did not actually complete on one of the MX 250s even though dashboard said it did.  We did a factory default and let it do its thing from scratch and the issue resolved itself.  We may have also had an issue with DHCP, I thought the MX already had a static IP address.  For your case, I would make your backup the mater, and then factory reset the other one, and see if it resolves the issue.  And definitely make sure you have a support case open.
hilehoffer
One other thing to note, the MX 250s run better on the 14 code. I know it is beta, but I think that train got started to better support the MX 250/450 line.
