Hello guys,
Have any of you try out the new release of MX v19 to have automatic failover between primary and secondary IPSec VPN Tunnels ?
Linked to this documentation : https://documentation.meraki.com/MX/Site-to-site_VPN/Primary_and_Secondary_IPsec_VPN_Tunnels
We are using IPSec peers for our proxy SaaS solution, all internet flow are going through the tunnel.
Today, we are playing with the tags to perform a manual failover, so we are waiting for this feature for a long time.
We've tried it on MX67 with MX 19.1.9 version, but we encountered some issues.
By default, we have our two IPSec peers and it's working well :
When we want to perform a failover, to simulate, we create an ACL on switch side to block trafic to the primary peer.
After that, we can see that the primary peer goes down :
But if we check with packet capture on IPSec VPN interface, we will se the packet going out the VPN, but we will not receive any return packet.
I think it's not an issue on our proxy saas solution because the manual failover it's working as expected.
Have you encounter the same issue?
