HI,
1. What does Max Device Count mean?
It means the maximum number of active, concurrent client devices that are passing traffic through the MX.
This refers to devices that are actively generating traffic, not just connected or idle clients.
This includes wired and wireless clients (if the MX has Wi-Fi) that route traffic through the MX.
It does NOT refer to Meraki devices such as switches or APs, unless they are generating user data traffic themselves.
2. Does Max Site-to-Site VPN Tunnel Count refer to AutoVPN tunnels?
Yes, it refers to the maximum number of active site-to-site VPN tunnels, including AutoVPN tunnels and non-Meraki VPN peers.
If you are using AutoVPN in a mesh, each tunnel between MX hubs or spokes counts.
Each non-Meraki VPN peer also counts toward this limit.
3. What does Max Client VPN Tunnels mean?
Refers to the maximum number of active, concurrent Remote Access VPN users using the MX.
These are users who connect via VPN from their laptops, mobile phones, or remote devices using Meraki's built-in Client VPN (L2TP over IPsec) feature.
This limit does not apply to site-to-site tunnels, only to users who access the network remotely via a VPN client.
For more information, see the datasheet. I hope this helps you.
https://meraki.cisco.com/product-collateral/mx-family-datasheet/?file
