MX operating in HA and Firewall 2xFPR1120-NGFW-K9 for Any connect/encryption suites and features
What's the recommended way to cable and configure 2x MX75/85 operating in HA and Firewall 2xFPR1120-NGFW-K9 for Any connect/encryption suites and features like posturing, etc capabilities? Any design recommendation please.
So assuming as per your previous reply that design would be like primary MX85 will have primary WAN connection and secondary MX85 will have secondary WAN connection below MX 85s 2xFPR1120-NGFW-K9 and below that MS core switches and below that access MS switch along with MR access points as I am looking for SD WAN perspective??
What do you mean with below? Behind? I would typically put all four WAN ports (2*MX, 2*FTD) directly on the internet. All four LAN ports are in the LAN connected to your MS.
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_7fb621f17e4df","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_7fb621f17e4df_0","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_7fb621f17e4df_1","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_7fb621f17e4df_2","feedbackSelector":".InfoMessage"});
LITHIUM.AutoComplete({"options":{"autosuggestionAvailableInstructionText":"Auto-suggestions available. Use Up and Down arrow keys to navigate.","triggerTextLength":4,"autocompleteInstructionsSelector":"#autocompleteInstructionsText_7fb62169760f6","updateInputOnSelect":true,"loadingText":"Searching...","emptyText":"No Matches","successText":"Results:","defaultText":"Enter a search word","autosuggestionUnavailableInstructionText":"No suggestions available","disabled":false,"footerContent":[{"scripts":"\n\n;(function($){LITHIUM.Link=function(params){var $doc=$(document);function handler(event){var $link=$(this);var token=$link.data('lia-action-token');if($link.data('lia-ajax')!==true&&token!==undefined){if(event.isPropagationStopped()===false&&event.isImmediatePropagationStopped()===false&&event.isDefaultPrevented()===false){event.stop();var $form=$('
