MX dhcp
Mateen1
MX dhcp
Hi guys, I want to configure DHCP pool on MX locally,  but for same clients I want to relay DHCP packet to Cisco ISE. Because we are doing profiling using Cisco ISE.
We have MX68 as aur L3 Gateway and it will also assign IP addresses for users.
Kindly share some inputs.
5 Replies 5
Remember DHCP forwarding only worked with a clients initial broadcast DHCP request. DHCP renewals are unicast packets to the DHCP. ISE will never see those from DHCP forwarding.
https://ciscocustomer.lookbookhq.com/iseguidedjourney/ise-profiling-design
Mateen1
Hey, could you please help with some specific links with MX config. the requirement is same as shared in above link.
rdominguez
Hello @Mateen1. Unfortunately, the MX can either act as a DHCP server or as a relay. It cannot do both at the same time.  And, as @alemabrahao has already mentioned, once a device has an IP address, the DHCP process is different in terms of renewal.
https://documentation.meraki.com/General_Administration/Cross-Platform_Content/Configuring_DHCP_Serv...
Mateen1
So, in that case case how we will do profiling by using DHCP probes on ise ,and same time MX will also work as DHCP server for client.
bhilgenkamp2024
Did you find a way to do this?
