MX dashboard display issue
GaryShainberg
Has anyone else noticed that there appears to be some issues with MX's and the dashboard, I have multiple MX's on multiple networks in multiple organisations and they are all having issues with showing the MX ports and DHCP data - anyone else seeing this or is it just me that has network gremlins !!!
CTO & Solutioneer
CMNA, CMNO, ECMS2
SNSA, SNSP
2 REPLIES 2
PatrickRead
We are seeing the same issues and have done for the last 6 hours.
Looks like it is working again - guess the big engineer in the sky fixed it
CTO & Solutioneer
CMNA, CMNO, ECMS2
SNSA, SNSP
