MX cellular with IPv6?
ksumann
is it possible to run the inbuilt cellular with IPv6 only?
The device is used to create a site-to-site VPN. CGNAT will break the connection so we got a SIM with a fixed IPv6 prefix (only IPv6) but the MX is not connecting, it gets no IPv6.
Using another APN, we got an IPv4 and an IPv6 but with CGNAT which isn't working.
Any ideas?
https://documentation.meraki.com/?title=MX/Other_Topics/IPv6_Support_on_MX_Security_%26_SD-WAN_Platf...
Have you checked the documentation?
I don't know the answer.
I don't think so "right now", but I think a lot of work is going into this area.  You'll have to run a bleeding edge firmware on the spoke and the hub to stand any chance.
Try asking support if there is any early access beta for AutoVPN over IPv6 you might be able to go on.
