MX as an internal Firewall
johnnyw827
Trying to set up a MX as an internal firewall in routed mode (can't connect to Meraki dashboard at the moment). I have a Cisco Catalyst 9404 port set up as a trunk with the native vlan set to 903. That is plugged into a mx100 with the internet (WAN) link set up with VLAN tagging - 903 and a /30 IP that is in the same subnet as SVI VLAN 903. Is this configuration supported?
KarstenI
Make sure that WAN1 can get out and you should be good to go. This WAN interface doesn't have to do anything regarding firewalling. If you have dashboard access you can do all your firewalling on your VLAN-traffic.
KarstenI
As long as the MX can reach the dashboard, it can be used as an internal firewall. However, I don't think the MX is the optimal choice for this.
johnnyw827
The link doesn't come up, so I don't think it's a supported configuration. We do the same thing for MS switches, and it works fine. I agree that it's a poor choice for internal firewalling.
KarstenI
GreenMan
Meraki Employee All-Star
Why set up the link between the link between the Catalyst and the MX as a trunk?   While you can do this, it doesn't add much, as you can't operate multiple SVIs over that link.   I'd just go for an access setup in your chosen VLAN, without any tagging.   Hard to say if the MX is appropriate as a purely internal firewall, without knowing exactly what you're wanting from it, though it is certainly true to say this is a fairly rare deployment scenario for an MX.   Remember that, by default, traffic between different VLANs is permitted by an MX - you'd need to configure specific deny rules.    You might also want to look into using no-NAT on the WAN interface:  https://documentation.meraki.com/MX/Networks_and_Routing/NAT_Exceptions-No_NAT_on_MX_Security_Applia...
