MX and Umbrella SIG IPSec Tunnel
Aousien
Meraki SDWAN Hub and Spokes (200 Spokes) - customer needs SIG tunnel from each spoke to Umbrealla- and No we cannot use secure connect - so we have to do it old school,
The question is , Can I create a single non-Meraki IPSec tunnel to cover all my Meraki spoke sites, or do I need a separate tunnel for each site so 200 NMVPN and use tag for each network/tunnel ?
Thanks.
6 Replies 6
The documentation suggests that you should configure a tunnel and use Tags with separated tunnels.
https://documentation.meraki.com/MX/Site-to-site_VPN/MX_and_Umbrella_SIG_IPSec_Tunnel
Aousien
where in the document you shared it says Tags with separated tunnels ? I cannot see that , it says use tag , and that tag can be one tag assigned to 100 networks as I am reading it.
You need a separate tunnel for each site.
Aousien
so for 250 sites , you will create and configure 250 NMVPN peers and use tags to assign each tunnel to a site ? or can you configure a single NMVPN tunnel , and that can be used by all sites ?
I know each site will build a tunnel , but from config perspective, 1 VMVPN tunnel or 250 ? thanks.
You should be able to define a single tunnel on the Meraki side (it will automatically get applied to al 250 sites).  I expect you'll need to configure 250 tunnels on the Umbrella side.
I'm not familiar with NMVPN or VMVPN.  Maybe DMVPN?  Meraki doesn't support that.
You could consider putting a VMX into Amazon AWS or Azure, use AutoVPN to build all your VPNs automatically to there, and then create a single tunnel from AWS/Azure to Umbrella SIG.
