>If issues arise I gather Meraki won't troubleshoot with you because it's BETA?
I can only share my experience with beta features. Generally they will try and help, but if you run into something that is broken - then it is bad luck.
>And the million dollar question, when will Meraki make 15.x a stable rls candidate? 3-6 months, 1 year?
This is a wild guess. I would say at least 12 months. My personal impression is that we only get a stable release canidate change to a new major version once per year.
>I'm in a scenario where I "need" (Don't ask) to use a MX as a simple router, no NAT no ACL (ingress/egress) - there is another firewall in place which will reside off the MX's LAN interface. That firewall will be performing the NAT/Firewall function.
Have you considered using the MX in layer 2 mode? It sounds so much simpler in your case ...
https://documentation.meraki.com/MX/Networks_and_Routing/Passthrough_Mode_on_the_MX_Security_Applian...
