MX and No-NAT operation
General-Zod
Greetings
Has anyone out there had much experience in using the No-NAT feature in BETA release 15.x?
Are there known issues if you leverage this feature?
If issues arise I gather Meraki won't troubleshoot with you because it's BETA?
And the million dollar question, when will Meraki make 15.x a stable rls candidate? 3-6 months, 1 year?
I'm in a scenario where I "need" (Don't ask) to use a MX as a simple router, no NAT no ACL (ingress/egress) - there is another firewall in place which will reside off the MX's LAN interface. That firewall will be performing the NAT/Firewall function.
Thanks in-advance
2 Replies 2
I can only share my experience with beta features.  Generally they will try and help, but if you run into something that is broken - then it is bad luck.
This is a wild guess.  I would say at least 12 months.  My personal impression is that we only get a stable release canidate change to a new major version once per year.
Have you considered using the MX in layer 2 mode?  It sounds so much simpler in your case ...
https://documentation.meraki.com/MX/Networks_and_Routing/Passthrough_Mode_on_the_MX_Security_Applian...
Thanks for your reply.
Passthrough mode is a no go as the carrier will _only_ supply a initial /30 public block per service. They will then route any additional space (in this case a /29) to the /30 CE. There are 2 x PAN's that are in HA that will consume the /29 for the WAN setup. So I'm looking at the MX WAN having the /30 and the LAN having the /29, so it must be routed mode.....sales people.
