MX and Catalyst 9800
Icneto
Hi there!
Does de MX appliance and active directory works without a wireless concentrator feature or i must have and configure this feature.
I'm trying to "connect" thru wirelles catalyst 9800 controller but clients only show as wired, even when change the filter on dashboard.
already reviewd all the meraki documentation and ts pages. All requirements are set.
Regard,
Ibero C. Neto
VPorts- Port Authority
1 Reply 1
KarstenI
Every wireless client that connects with a non-Meraki infrastructure shows up as a client connected to the switch where the traffic enters the Meraki network. Works as designed. I would assume this will change when you add your 9800 in monitor mode to the Meraki Dashboard:
https://documentation.meraki.com/Cloud_Monitoring_for_Catalyst
