MX and AD Server Integration
KSM
Hi~
I am testing the integration between Meraki MX and AD server.
However, other products work well with AD server.
However, only Meraki is not working with the AD server.
I looked into it, and it seems like it's failing because it only supports STARTTLS.
What should I check on the AD side?
The MX integrates with AD for several different things.  What feature specifically are you trying to integrate with AD?
KSM
I'll try one more time using the method you suggested.
Thank you for your response.
