MX Warm Spare
iores
MX Warm Spare
I have two MX which I would like to configure as a warm spare, and have few questions:
  1. Is it enough to connect MXs with L2 link via switch? In other words, I am planning to do so with the trunk which will be arriving from the downstream switch (single switch or stack).
  2. Do I need to create some "heartbeat" VLAN between them? As per my understanding, MXs will exchange VRRP messages for all created VLANs so if MX is my L3 device, then, perhaps, I don't need heartbeat VLAN.
  3. What will happen if one LAN SVI L3 interface (default gateway) goes down on active MX? I presume the standby MX will not take over just for this one L3 interface. For standby MX to takeover, the primary MX needs to be down completely, right?
  4. If MX is connected with two links to the same switch, does this mean that the switch will receive its own BPDUs since MX will forward BPDUs?
  5. I was reading this document. Page 5, Section 4, it says:
In order for Spanning Tree NOT to block the port to the PRIMARY MX, I had to switch the
cables on the downstream switch so it would favor the PRIMARY MX port. (the lowest port-
ID in spanning tree)
Why is this relevent if MXs are connected via one switch?
2 Replies 2
pdeleuw
Yes, a connection per switch is enough. The active MX will send VRRP heartbeats to the spare MX.
No, the recommended design is no direct, explicit connection for the heartbeat. And yes, the MX will send VRRP heartbeats for every VLAN.
I have never seen a single VLAN-Interface going down on a MX.
Yes.
This is not relevant when connecting the MX to a single switch. But this design is not recommended.
I recommend to read this article from Karsten: https://cyber-fi.net/index.php/2022/03/13/how-to-connect-the-meraki-mx-to-ms-switches/
