MX VRRP MAC Address bug ?
RaphaelL
Hi ,
We have multiple warm spaces and I have been taking packet capures and this is what I found :
MX450 Warm Space 15.40 VRRP MAC ADDRESS : e0:cb:bc:a3:9b:f8 burned-in MAC : e0:cb:bc:a3:9b:f8 ( Passthrough )
MX450 Warm Space 15.42.1 VRRP MAC ADDRESS : 2c:3f:0b:e6:ba:47 burned-in MAC : 2c:3f:0b:e6:ba:47 ( Passthrough )
MX250 Warm Space 14.53 VRRP MAC ADDRESS : cc:03:d9:25:be:f9 burned-in MAC : f8:9e:28:25:be:f9 ( Routed )
Does anyone have a Warm space with 15.44 or 15.44.1 that is willing to do a packet capture and compare with my finding ? It MIGHT be fixed in 15.44 or 15.44.1 but I'm not too sure.
Also , the MS documentation states : "The virutal MAC address will always begin with 88-15-44" then procedes to show a screenshot with the VRRP Mac adress from the RFC 5798 ( 00-00-5E-00-01-XX   , where XX = RID ). It's a bit confusing and there is a typo ( virutal ).
https://documentation.meraki.com/MS/Layer_3_Switching/MS_Warm_Spare_(VRRP)_Overview
The MX documentation doesn't state anything about the MAC adress so you would assume it is under the VRRP standard , which is false. It would be nice to include how the MAC is selected ( The First 3 octets for the virtual mac address will be "cc:03:d9" and is based on Primary MX.
https://documentation.meraki.com/MX/Deployment_Guides/MX_Warm_Spare_-_High_Availability_Pair
Some will say that I'm picky , you are 100% right 🙂
Ryan_Miles
Meraki Employee All-Star
Agreed the doc should go into more depth about how the virtual MAC process works. I will run this by MX PM for feedback.
If in the HA config you use the uplink IPs then you should see the physical MACs. If you use a VIP it will create a virtual MAC as you mentioned above.
I have just checked a coupe of HA pairs and have:
VPN concentrator mode - MX16.15 - virtual MAC beginning cc:03:d9, physical MACs begin e0:cb:bc (primary) and 68:3a:1e (warm spare)
Routed mode - MX16.16 - virtual MAC beginning cc:03:d9, I don't see physical MACs
RaphaelL
Great ! We now have answers to our questions  1- CC:03:D9 is always used on MX in Warm Space ( doesn't matter if it's concentrator or routed mode ) 2 - This ''issue'' is fixed on the MX 16.X branch , and seems to have been introduced in MX 15.XX and MIGHT be fixed in 15.44.1 ( still to be confirmed )
Thanks a lot for your time ! : )
RaphaelL
Late to the show ! But IT was fixed in MX15.44 !
