MX SD-WAN POV
Enrico_Romero
MX SD-WAN POV
Hi Team,
One of our client is requesting for a POV of Meraki MX's SD-WAN.
What are the requirements?
They are going to borrow one MX100 from us and I'm not familiar with SD-WAN.
The Meraki SD-WAN Deployment guide is not that clear to me.
Will the SD-WAN work if they only have one Meraki MX?
How can I showcase the SD-WAN on Meraki MX?
Is there a Step-by-Step SD-WAN POV guide?
Any information will also help.
Cheers
2 REPLIES 2
First, your customer can get kit by using the "Try and Buy" program.
https://meraki.cisco.com/form/trial
The hint really is in the term "WAN" - which implies at least two sites - which means you would need two MX's.  And to really show it off, at least one of those MX's should have two circuits attached.
Here is a CVD (Cisco Validated Design):
https://documentation.meraki.com/MX-Z/Deployment_Guides/SD-WAN_Deployment_Guide_(CVD)
This section in particular shows how to configure the magic:
https://documentation.meraki.com/MX-Z/Deployment_Guides/SD-WAN_Deployment_Guide_(CVD)#Adding_perform...
DavidH
Meraki Alumni (Retired)
Hi @Enrico_Romero,
It sounds like you'd be selling the Meraki gear to the customer? If so and if you are a registered Meraki partner, I'd suggest talking to your Sales rep, they will be able to help!
Thanks,
David
