MX Internet redundancy
pcanters
Question about how I can accomplish internet redundancy on an MX appliance when my second WAN/ISP is an internal BGP route on the core switch that the MX is connected to ?
I would have an MX with an internet connection plugged into WAN1. The idea is that when WAN1 goes down or things become unreachable on the WAN1 interface, I then dynamically route things back to the inside core switch rather than WAN 2 where I have a default route from an MPLS network to get me to the second ISP.
Not sure this is possible.
Anyone have any ideas on how to accomplish this ?
I have thought about plugging WAN 2 back into the core switch but unless I can leverage dynamic routing from the MX to the core switch dependent on WAN1 being present, I cant define an default route on the core as it would never allow traffic to transit out the MPLS WAN
TIA
In this case, IP SLA is the best way in my opinion.
I assumed that the gateway for your local LAN is the switch core, right? What is de model of your switch? Maybe you can create a route map on this switch.
pcanters
Yes...Switch core is default gateway for all vlans. It is a cisco 3850 so I could old school use object tracking there with IP SLA to get around the Meraki not being able to do this. The other thought is to take the MPLS and plug it into WAN2 but then I have probable BGP routing issues with advertising my local networks
pcanters
I kind of agree. As much as I wish I could do this on the Meraki MX, it's not really designed to handle this network setup. Thanks for the response
