MX CPU usage not available on Dashboard
Foysol
I can't see CPU usage from Summary Report. It's showing not enough data to displayCurrent version: MX 14.53
What is the issue?
6 Replies 6
It has never showed any data. Maybe  it's something they want to implement in the future.
Bruce
Yep, it’s always been the case, on MX14, MX15 and MX16 firmware - it’s never shown any data in any version I’ve seen. In all honesty I don’t know why Meraki keep it in the summary report.
Dunky
Appears ok in my Summary Report:
MX67's and MX84's running 15.42.1
BlakeRichardson
Possbily something you need to ask support to enable. As mentioned its always been there and never worked.
@Dunky not that one (whole organisation), pick an individual network with an MX in it and there is a chart on the left hand column at the bottom below device utilisation that never has data...
Dunky
@cmr Ahh yes, I can see what you mean now.
